Cập nhật lại dòng lệnh cho sản phẩm condusiv (ko áp dụng cho undelete)
What's new in Hidden Start 4.7
September 24th, 2019
  • Added "Manage Startup Items" command under the Tools menu
  • Fixed the title bar height of GUI Tool main window
  • Some other minor improvements and bug fixes
  • Added new user interface to provide easier access to features
  • Added sidebar navigation to access core features
  • Added new install mode options (15, 30 and 60 mins)
  • Added Dashboard, Exfiltration, Settings, Geography, White List, Black List, Forensics, Privacy, Events
  • Added event blocking log in addition to standard events
  • Improved process scanning performance
  • Eliminated duplicate process scanning in terminal services mode
  • Enterprise training mode also works with process monitoring
  • All options and settings are applied immediately
  • All core layer blocking is available in the settings option
  • Combined processes and hosts into traffic option with world map
  • Updated size and style of world map for clarity
  • Updated all tree based icons for high DPI scaling
  • Forensic tile maps to Forensics
  • Privacy Clean tile now mapped to Clean button within Forensics
  • System tile maps to Privacy
  • Added save option to Log file
  • Added refresh option to Log file
  • Fixed geolocation error on malformed data
  • Added many more statistics to new dashboard
  • Improved IPC performance
  • Left side of status bar now shows whether system is active
  • About dialog now includes build number
  • Fixed stack overflow when parsing deeply nested directories
  • Added HDPI icons for better scaling on large monitors
  • Updated Installer dependencies for reliability
  • Removed all dependencies on WMI
  • Updated Ad Blocking. Profiling and malware detection rules
What's new in Softros LAN Messenger 9.4.1
September 26th, 2019
Added:
  • Softros LAN Messenger version in user information hoverbox
  • Option to automatically bypass screen saver in remote desktop administration sessions
Fixed:
  • Issue with access to remote log files in "History Viewer" if Softros LAN Messenger is updated to versions 9.2.2 - 9.4
Improved:
  • "Delete messages older than" setting on "Logging" tab now also applies to multi-user conversation logs. Corresponding multi-user conversation log files will now be deleted to Recycle Bin
What's new in BlackFog Privacy 4.0.1
  • Fixed BSOD on Windows 10 when running with Device Guard enabled
  • Added notification to client when accessing a Fake News site
What's new in BlackFog Privacy 4.0.2
September 27th, 2019
  • Fixed BSOD when using Secure Boot mode which pages out memory
Acrylic Version 1.1.0 released on September 30, 2019
Acrylic files are hosted on external servers. If you want to check their integrity verify that their hashes match with the ones shown above.
  • Added support for the DNS-over-HTTPS protocol.
What's new in V-locity 7.0.218.0
September 30th, 2019
  • Improves system performance an average of 30-50% or more.
  • Guarantees to solve the toughest application performance problems like MS-SQL workloads, Oracle, ERP, VDI, EHR, Business Intelligence apps, CRM, Exchange, SharePoint, file servers, backup, and more.
  • Enhanced reporting.
  • No Reboot Required!
Cập nhật fix cho tất cả phần mềm của condusiv
  • Thêm Undelete <== để sử dụng mục này yêu cầu phải cài thêm ứng dụng chống phân mảnh. Ko có sẽ ko hoạt động.
  • Thêm đăng ký, đăng ký + reset, chỉ mỗi reset
  • Giải thích các mục cần thiết
  • Thêm tiêu đề về người đã giúp mình code tìm registry <== mình quên mất vụ này
Update lại Fix cho Condusiv
  • Sửa lại lệnh gọi
  • Sửa lại khoảng cách mục biểu
  • Thêm tự động bật, tắt dịch vụ V-locity khi chạy fix
Emsisoft phần thay đổi cập nhật cho bản dựng 2019.9 | Ngày 2/10/2019
Dành cho Emsisoft Antimalwre
  • Cập nhật lịch khởi động (áp dụng cho cập nhật các bản dựng lớn)
  • Cải thiện nhật ký sự kiện
  • Một vài điều chỉnh nhỏ và sửa lỗi
Dành cho MyEmsisoft/Bảng điều khiển Clound (mây)
  • Bảng tình trạng của thiết bị và chi tiết thiết bị (mới)
  • Hỗ trợ mới cho các mẫu chính sách phân cấp
  • Giao diện người dùng được cãi thiện trong nhiều phần
Link change logs | Link
pepePE
từ lâu đã sử dụng Emsisoft Antimalwre và hài lòng rằng nó rất tốt nhưng khó để có được khóa nối tiếp, cảm ơn vì đã chia sẻ :) {hug}
kezihenry
hôm nay vừa mua 1 key Emsisoft cho máy của vợ. Bác @Hamano Kaito cho hỏi khi hết hạn còn có cách nào kéo dài ngày sử dụng được nữa không để mình còn backup lại file setting. Cảm ơn bác.
@kezihenry | Quay lại #1 tìm mục cuối cùng (danh sách phần mềm), mở mục đó ra tìm cách fix emsisoft là sẽ biết được.
Bạn nên backup lại tệp a2settings lại để sau này có gì còn lôi ra làm lại được. Từ 1 tệp đó bạn có thể vượt bảo mật để xài cho X máy luôn đấy. <== cái này mình ko hướng dẫn
kezihenry
cảm ơn bác nhiều, để mình tự tìm tòi thêm.
What's new in Viscosity 1.8.1 (1632)
October 8th, 2019
Added:
+ Adopts native Windows U2F integration on Windows 10 1903+
Improved:
+ Ignores unnecessary pushed route-delay commands
Fixed:
+ Resolves issue where IPv6 DNS Servers may not be used
+ Various bug fixes and enhancements
Realtek High Definition Audio Driver Mod
  • 05-10-2019: mbfilt64.sys file version to 6.10.0.17 & VC++ appx files
What's new in DNSCrypt Proxy 2.0.28
October 13th, 2019
  • Invalid server entries are now skipped instead of preventing a source from being used. Thanks to Alison Winters for the contribution!
  • Truncated responses are immediately retried over TCP instead of waiting for the client to retry. This reduces the latency for large responses.
  • Responses sent to the local network are assumed to support at least 1252 bytes packets, and use optional information from EDNS up to 4096 bytes. This also reduces latency.
  • Logging improvements: servers are not logged for cached, synthetic and cloaked responses. And the forwarder is logged instead of the regular server for forwarded responses.
Cập nhật thêm key cho Salview
DNSCrypt Proxy 2.0.29-beta.1 Released this Oct 14, 2019
+ Preliminary support for anonymized DNS is here! <== hỗ trợ DNS ẩn danh (Beta)
Để biết thêm chi tiết về bổ sung như trên các bạn vào đây để tham khảo | Link
What's new in BlackFog Privacy 4.0.4
October 17th, 2019
  • Whitelisted several system Powershell scripts from MS
  • Added some memory checks around hardware serial numbers
  • Rounded memory size when reporting
  • Optimized database flushing for performance
  • Increased event column size for timestamp
What's new in Service Protector 6.5.3.71
October 18th, 2019
  • New features:
  • Added the ability to restart the service when the PC resumes fom a sleep/hibernation/low-power event.
  • Fixes & Improvements:
  • Single-CPU percent is now properly reported.
  • Present additional informtion on the registration windows.
  • Mention when the 30-day trial expires in the main window's title.
Cập nhật thêm dòng lệnh mới cho IDM (dòng lệnh 3). Với dòng lệnh mới này sẽ tiện hơn 2 dòng lệnh trước là bảng lệnh sẽ ko còn hiển thị nữa (chỉ áp dụng cho tệp lệnh đã nén thành .exe)
Và các mục biểu được thay thế thành bảng thông báo và Inputbox. Phần chi tiết các bạn xem ở #1
Link | mh_auth_or_register
