- Vâng, cách làm đó giúp khách hàng chủ động chuyển bản quyền linh hoạt từ máy này sang máy khác nhưng đây cũng là kẽ hở trong việc bảo vệ bản quyền của lab bác à.
Rìu Chiến Vàng
Lúc đang dùng thì nó cũng hay nháy lên thông báo nhắc nhở và hiện tiếp cái hình thứ hai của cháu đó, bác cứ tắt đi cho xong, để xem chừng nào nó mới làm thật gắt gao như Eset, không có key thì đỏ lè đó cháu.
What's new in Zemana AntiMalware 3.1.358 Beta
July 8th, 2019
  • Custom Scan feature is in Beta! Right click on any file/folder and Scan with Zemana AntiMalware!
  • False Positives in Real-time module fixed
  • Logging improvements
  • Other minor bug fixes and improvements
What's new in Soundop 1.7.2.0
July 15th, 2019
  • Supported solo safe mode of track.
  • Supported locking clip in time.
  • Added clip state of stretch and pitch.
  • Supported save and load workspace layout.
  • Support adding multiple shortcut key for one command.
  • Supported exporting command list to clipboard.
  • Added commands to adjust time selection and edit-cursor.
  • Added commands for scroll and zoom operation.
  • Added commands to move selected track up and down.
  • Added a command to edit track color.
  • Added commands to select clips in a track.
  • Supported linking source file for a clip.
  • Added command to link all offline source files.
  • Add a command to silence clips in the time selection.
  • Add a command to trim clips.
  • Add a command to split all clips under edit-cursor.
  • Add commands to nudge clips.
  • Add a command to rename clip.
  • Add a command to rename clip group.
  • Add commands to delete markers.
  • Add a command to show source file of the selected clip in the Files panel.
  • Supported managing offline files in the Files panel.
  • Added a command to zoom in at edit-cursor.
  • Added commands to toggle track mute, solo, record and monitor.
  • Added commands to change options of playback.
  • Added a command to toggle enabled state of all channels.
  • Added a command to analyze frequency.
  • Added commands to insert audio files to mixspace and CD project.
  • Added commands to add files to CD project and batch processor.
  • Added commands to switch time display format.
  • Added commands to switch projects.
  • Added a command to maximize a panel group.
  • Added a command to show project file in Explorer.
  • Modified layout of the main menu.
  • Modified some default shortcut keys.
  • Fixed some bugs
Zemana AntiMalware 3.1.375 | Tuesday, July 16, 2019 3:21 PM
  • This is the stable release of the previous BETA version (3.1.375)
Zemana AntiMalware 3.1.375 Free | Tuesday, July 16, 2019 3:21 PM
Zemana AntiMalware 3.1.375 Beta | Tuesday, July 16, 2019 3:20 PM
  • New version of realtime AI engine
  • Initialization crashes are fixed
  • Realtime detection crashes are fixed
  • Issues with Cloud Scanner are fixed
  • Other minor fixes and improvements
giờ có gì thay được adguard ko bác hamano chứ ko có Cr@ck dùng k được @@
Adguard mình ko còn dùng nữa, vì lỗi quá nhiều. Để coi có thời gian rãnh mình sẽ test lại fix hoặc nếu làm biếng mình sẽ dùng fix của team thứ 3 gởi qua inbox cho bạn xài.
Giờ có cách đấy nhưng mình ko công khai nữa, vì sẽ bị họ fix mất
lazyboy
Ok thanks bác, vậy h bác chặn quảng cáo bằng gì thế ạ?
Mình dùng ublock
Nếu bạn ko dùng win ltsc thì bạn qua bên đây dùng của việt nam làm này | xài rất ok đấy
Lỗi gì thì pm chủ topic sẽ khắc phục ngay và luôn
What's new in Snort 2.9.14
July 19th, 2019
  • New AdditionsL
  • Added support for wild card port numbers in host cache and overwriting port service AppId.
  • Added new client patterns to prompt client validation.
  • Added SMTP Microsoft Outlook client for Mac.
  • Added a new preprocessor alert 120:27 to alert if there is no proper end-of-header.
Improvements:
  • Improved appId detection for proxied traffic.
  • Fix to ensure Snort is ready for packet commencing before DAQ starts.
  • Fix for enabling flow profiling mode without restarting Snort detection engine.
Cập nhật phần thay đổi | Ảo hóa âm thanh Sound Blaster
20-07-2019: Update Creative UWP PRC Service to 2.0.2.5
15-06-2019: Downgrade mbfilt64.sys file version to 6.10.0.15 in order to keep 192kHz exist
ExpanDrive 7 <== Phần thay đổi cập nhật bản 7
Cập nhật phần thay đổi. So với phiên bản 6 trước đó bản 7 lần này sẽ có nhiều thay đổi như sau
Được tích hợp vào Finder và Explorer <== đã có từ build 6, ko bàn tới
Đồng bộ hóa ngoại tuyến (tức là offline đấy) thông minh
Giải thích:
Chọn tệp để kết nối (truy cập) ngoại tuyến làm việc mà không cần đến kết nối mạng. Đồng bộ hóa với đám mây diễn ra tự động khi có kết nối mạng lại. Các tệp khác được truy cập (kết nối) theo yêu cầu từ đám mây, không chiếm dung lượng đĩa khi sử dụng.
Nay với phiên bản 7 đã có mặt trên hệ thống linux
Hỗ trợ các hệ thống Linux như hình bên dưới
honeyview_linux-jpg.5348
Tích hợp tìm kiếm
Giải thích:
ExpanDrive sẽ được hook vào Tìm kiếm Spotlight trên Mac và tìm kiếm tệp trên Windows. Nhanh chóng tìm kiếm bất cứ thứ gì mà bạn cần từ bộ nhớ từ xa. Trình duyệt lưu trữ tích hợp có hỗ trợ bổ sung tìm kiếm nhanh từ phía máy chủ.
Khóa tệp nhiều người dùng
Giải thích:
ExpanDrive sẽ phân quyền các tệp và khóa các tài liệu của Microsoft Office trên mây. Nếu người dùng đang chỉnh sửa tài liệu Office, thì những người còn lại sẽ chỉ có thể mở để đọc cho đến khi người chỉnh sửa đó tắt đi.
Quản lý phiên bản tệp
Giải thích:
Dễ dàng truy cập đến các phiên bản cũ hơn của tệp hỗ trợ lưu trữ trên mây, bao gồm Box, Dropbox, S3, Google Drive, OneDrive và Sharepoint.
Kết nối đến bất kỳ dịch vụ mây
Kết nối đến tất cả các nhà cung cấp lưu trữ mây lớn hoặc máy chủ của riêng bạn. Với một ứng dụng duy nhất nhưng có thể kết nối đến:
  • Dropbox
  • Google Drive and Google Team Drives
  • Amazon Drive
  • Box
  • OneDrive and OneDrive for Business
  • Sharepoint
  • Nextcloud
  • Wasabi
  • Backblaze B2
  • SFTP/FTP, WebDAV
  • SMB/Windows File Sharing
Tải nền nhanh hơn
Giải thích:
ExpanDrive có công cụ kết nối đa luồng, có thể đạt tốc độ lên đến 500% so với phiên bản trước.
ExpanDrive thực hiện chuyển tệp song song trong chế độ nền để bạn có thể chuyển tệp ngay khi đối mặt với mạng không ổn định. Tiếp tực làm việc và ngừng chờ chuyển để hoàn thành
Trang chủ | https://www.expandrive.com/
Version 3.1.1 Jul-26-2019
  • Bugfix Files not displayed with NFD Unicode normalization form in filename
  • Bugfix Failure authenticating with STS (S3, Credentials from AWS Security Token Service) (#10746)
  • Bugfix Display alerts as sheet of bookmark window if open (macOS)
Version 3.1.0 Jun-25-2019
  • Feature Notification for newly added when synchronizing folders
  • Feature Action in notification about changed files to allow reveal of file or folder
  • Feature Custom disk icon for favorite in Finder sidebar (macOS)
  • Feature Default protocol selection for NextCloud & ownCloud
  • Feature Create share links in NextCloud & ownCloud
  • Bugfix Resume synchronization on retry if paused
  • Bugfix Faster detection of files changed on server previously synchronized
  • Bugfix Faster detection of new files not previously synchronized
  • Bugfix Saving file in some applications does not immediately synchronize to server
  • Bugfix Icon display in tray when using light scheme (Windows)
  • Bugfix Connect with application key restricted to single bucket (Backblaze B2)
  • Bugfix Failure saving files from Xcode (macOS)
  • Bugfix Missing files when previously trashed and restored (Google Drive)
  • Bugfix Exclude local cache from Time Machine backups (macOS)
Version 3.0.2 Jun-05-2019
  • Feature Japanese (日本語) Localization
  • Feature Notification on conflict when synchronizing files
  • Feature Add hostname and username to bookmarks in menu
  • Feature Support to rename files (Backblaze B2)
  • Bugfix Memory usage with indexer running
Loại bỏ DesktopPlant thay vào đó là Bàn làm việc ma thuật dành cho bé !
Phần thay đổi sẽ được cập nhật sau...
Cập nhật fix sau....
nghiabros
Adguard đã fix patch rồi nhé các bạn, hết xài chùa được rồi nhé !
Đã tìm được cách fix nhưng ko share nữa ! Ahihihi {EMO_065} <== đừng có mà inbox mình, vì mình sẽ ko trả lời bất kỳ tin nhắn nào cả {tongue}
Mình có thắc mắc vì sao bác không chia sẻ nhỉ? Vì người bên forums kia sao biết được ai share ra ngoài đâu ta {amazed}
Cập nhật phần thay đổi cho Emsisoft build 2019.7 | https://blog.emsisoft.com/en/33663/new-in-2019-7-local-traffic-relay-to-proxy-and-cache-updates/
Emsisoft Anti-Malware
  • New traffic relay/cache proxy feature. | Tính năng lưu lượng Relay/Cache Proxy mới
  • New remote management integration with Datto RMM. | Quản lý tích hợp từ xa mới với Datto RMM
  • Several minor tweaks and fixes. | Một số điều chỉnh nhỏ và sửa lỗi
Note: This update may require a system reboot in certain situations. We apologize that we couldn’t find a way to avoid that. | Chú thích: Bản cập nhật này có thể sẽ yêu cầu khởi động lại hệ thống trong tính huống nhất định. Chúng tôi thành thật xin lỗi vì chúng tôi không thể tìm được cách nào tốt hơn.
MyEmsisoft/Cloud Console
  • New traffic relay/cache proxy feature. | Đã nói ở trên
  • Added options to cancel and restart a subscription. | Thêm tùy chọn để hủy bỏ và khôi phục lại đăng ký
  • Improved policy template editor. | Cải thiện chính sách điều chỉnh tệp mẫu
  • Improved workspace dashboard, now also displaying unmanaged devices. | Cãi thiện không gian bản điều khiển, bây giờ sẽ hiển thị các thiết bị không kết nối
  • Added workspace removal feature. | Thêm tính năng loại bỏ không gian làm việc
  • Improved mobile app view. | Cải thiện xem trên ứng dụng cho điện thoại
  • Improved login procedure. | Cải thiện cách thức đăng nhập
  • Improved user account security. | Cải thiện bảo mật tài khoản người dùng
  • Improved infrastructure hardening against attacks. | Cải thiện cơ sở hạ tầng để bảo vệ các cuộc tấn công
  • Several minor tweaks and fixes. | Như đã nói ở trên
kezihenry
emsisoft hiện thông báo lỗi, yêu cầu khởi động lại máy, báo lỗi lần cập nhật gần nhất cách đây 27 ngày. Khởi động lại máy trở lại bình thường. Nói chung cập nhật không có gì mới đặc biệt các bác ạ. Cứ ổn định thế này thì gắn bó lâu dài với emsisoft thôi, nhẹ nhàng mà hiệu quả.
Trong phần thay đổi cập nhật có ghi chú thích mà. Những đợt trước thì cập nhật ko bị khởi động lại, riêng build này thì khởi động lại <== khả năng cao họ đang cải tiến 1 cái gì đó liên quan đến khóa đăng ký
What's new in DS WASAPI ASIO Router Mixer 1.0.40.132
August 4th, 2019
  • Fixed enabling ASIO devices that have only input or only output channels.
