Reviews  So sánh thông số kỹ thuật giữa Nikon D6 và Nikon D5
VNZ-ROAD
Ngoài giá tiền đắt hơn D5 thì phiên bản D6 cũng có nhiều cải tiến quan trọng. Mời anh em xem bảng so sánh dưới đây
Nikon D6Nikon D5
$6,497$5,497
Lens MountNikon F mount (with AF coupling and AF contacts)Nikon F bayonet mount
Effective Pixels (Megapixels)20.8 million20.8 million
Sensor Size35.9 mmx23.9 mm35.9 mmx23.9 mm
Image Sensor FormatFXFX
File Format Still ImagesJPEG: JPEG-Baseline compliant with fine (approx 1:4), normal (approx 1:8), or basic (approx 1:16) compression (size priority); Optimal quality compression available
NEF (RAW): 12 or 14 bit, lossless compressed, compressed, or uncompressed; large, medium, and small available (medium and small images are recorded at a bit depth of 12 bits using lossless compression)
NEF (RAW) + JPEG: single photograph recorded in both NEF (RAW) and JPEG Formats
JPEG: JPEG-Baseline Compliant with Fine (approx 1:4), Normal (approx 1:8) or Basic (approx 1:16) Compression
TIFF (RGB)
Storage MediaCFexpress (Type B)
XQD Type Memory
CompactFlash© (CF) (Type I, compliant with UDMA)
XQD Type Memory
Card Slot2 CFexpress (Type B) cards or 2 XQD memory type cards
The card in Slot 2 can be used for overflow or backup storage, for separate storage of NEF (RAW) and JPEG copies of photos taken at image quality settings of NEF (RAW) + JPEG, or to store separate copies of JPEG photos at different sizes and compression ratios; pictures can be copied between cards
2 XQD memory type cards or
2 CompactFlash© (CF) cards
Viewfinder Frame CoverageFX (36x24):100% horizontal and 100% vertical (Approx.)
1.2x (30x20):97% horizontal and 97% vertical (Approx.)
DX (24x16):97% horizontal and 97% vertical (Approx.)
5:4 (30x24):97% horizontal and 100% vertical (Approx.)
1:1 (24x24):95% horizontal and 100% vertical (Approx.)
16:9 (36x20):100% horizontal and 96% vertical (Approx.)
Viewfinder Magnification0.72x (50 mm f/1.4 lens at infinity, –1.0 m–1) (Approx.)0.72x (50 mm f/1.4 lens at infinity, –1.0 m–1) (Approx.)
Viewfinder Eyepoint17 mm (-1.0 m¯¹) from center surface of viewfinder eyepiece lens17 mm (-1.0 m¯¹)
Fastest Shutter Speed1/8000 sec.1/8000 sec.
Slowest Shutter Speed900 sec.30 sec.
Top Continuous Shooting Speed at Full Resolution14 frames per second12 frames per second
14 frames per second with mirror up
Exposure Compensation±5 EV in increments of 1/3, 1/2 or 1 EV±5 EV in increments of 1/3, 1/2 or 1 EV
Exposure BracketingYes2 to 5 frames in steps of 2 or 3 EV
2 to 9 frames in steps of 1/3, 1/2, 2/3 or 1 EV
Picture ControlAuto
Creative Picture Controls (Dream, Morning, Pop, Sunday, Somber, Dramatic, Silence, Bleached, Melancholic, Pure, Denim, Toy, Sepia, Blue, Red, Pink, Charcoal, Graphite, Binary, Carbon)
Flat
Landscape
Monochrome
Neutral
Portrait
Standard
Vivid
Selected Picture Control can be modified
Storage for custom Picture Controls
Flat
Landscape
Monochrome
Neutral
Portrait
Standard
Vivid
User-customizable Settings
ISO SensitivityISO100 -102,400Choose from step sizes of 1/3, 1/2, and 1 EVCan also be set to approx. 0.3, 0.5, 0.7, or 1 EV (ISO 50 equivalent) below ISO 100 or to approx. 0.3, 0.5, 0.7, 1, 2, 3, 4, or 5 EV (ISO 3,280,000 equivalent) above ISO 102,400; auto ISO sensitivity control availableISO100 -102,400Can also be set to approx. 0.3, 0.5, 0.7, or 1 EV (ISO 50 equivalent) below ISO 100 or to approx. 0.3, 0.5, 0.7, 1, 2, 3, 4, or 5 EV (ISO 3,280,000 equivalent) above ISO 102,400; auto ISO sensitivity control available
Dynamic AF ModeYesNumber of AF points: 25, 72 and 153 (3D-tracking)
Auto-Area AF ModeYesYes
Focus ModesContinuous-servo (AF-C)
Face-Priority AF available in Live View only and D-Movie only
Full-time Servo (AF-A) available in Live View only and D-Movie only
Manual (M) with electronic rangefinder
Normal area AF
Single-servo AF (AF-S)
Wide area AF
Maximum Autofocus Areas/Points105153
Flash BracketingYes2 to 5 frames in steps of 2 or 3 EV
2 to 9 frames in steps of 1/3, 1/2, 2/3, or 1 EV
Top FP High Speed SyncUp to1/8000Up to1/8000
Flash Sync ModesFront-curtain sync (normal)
Rear-curtain sync
Red-Eye reduction
Red-Eye reduction with slow sync
Slow sync
Off
Auto FP High-Speed Sync supported
Rear-curtain sync
Red-Eye reduction
Slow rear-curtain sync
Slow sync
Flash Compensation-3 to +1 EV in increments of 1/3, 1/2 or 1 EV-3 to +1 EV in increments of 1/3, 1/2 or 1 EV
Nikon Creative Lighting System (CLS)i-TTL flash control, radio-controlled Advanced Wireless Lighting, optical Advanced Wireless Lighting, modeling illumination, FV lock, Color Information Communication, Auto FP High-Speed Sync, AF-assist for multi-area AF (viewfinder photography), unified flash controlCLS Supported
White BalanceAuto (3 types)
Choose color temperature (2500K to 10000K)
Cloudy
Direct Sunlight
Flash
Fluorescent (7 types)
Incandescent
Natural Light Auto
Preset manual (up to 6 values can be stored, spot white balance measurement available during live view)
Shade
All except choose color temperature with fine-tuning
Auto (3 types)
Cloudy
Direct Sunlight
Flash
Incandescent
Shade
White Balance BracketingYes2 to 9 exposures in increments of 1, 2 or 3 EV
Live View ShootingPhotography Live View Mode
Movie Live View Mode
Photography Live View Mode with available Silent Mode
Movie4K UHD 3,840x2,160 / 30 fps
4K UHD 3,840x2,160 / 25 fps
4K UHD 3,840x2,160 / 24 fps
Full HD 1,920x1,080 / 60 fps
Full HD 1,920x1,080 / 50 fps
Full HD 1,920x1,080 / 30 fps
Full HD 1,920x1,080 / 25 fps
Full HD 1,920x1,080 / 24 fps
Full HD 1,920x1,080 crop / 60 fps
Full HD 1,920x1,080 crop / 50 fps
Full HD 1,920x1,080 crop / 30 fps
Full HD 1,920x1,080 crop / 25 fps
Full HD 1,920x1,080 crop / 24 fps
HD 1,280x720 / 60 fps
HD 1,280x720 / 50 fps
Actual frame rates for 60p, 50p, 30p, 25p, and 24p are 59.94, 50, 29.97, 25, and 23.976 fps respectively
Quality selection available at all sizes except 3,840 x 2,160 when quality is fixed at (high)
High quality available at all frame sizes, normal quality available at all sizes except 3,840 x 2,160
Movie AudioBuilt-in stereo or external microphone with attenuator option; sensitivity adjustableBuilt-in microphone, stereo
External stereo microphone (optional)
Microphone sensitivity can be adjusted
Monitor Size3.2 in. diagonal3.2 in. diagonal
Monitor Resolution2,359,000 Dots2,359,000 Dots
Monitor TypeTFT touch-sensitive LCDWide Viewing Angle Touch TFT-LCD (Touch for playback only)
Playback FunctionsAuto Image Rotation
Full-frame and thumbnail (4, 9, or 72 images)
Highlights
Histogram Display
Index Marking
IPTC information embedding and display
Location Display
Movie Playback
Movie Slideshow
Photo Information
Photo Slideshow
Picture Rating
Playback with Playback Zoom
Playback Zoom Cropping
Voice Memo
Auto Image Rotation
GPS data display
Highlights
Histogram Display
Image Comment
Movie Playback
Movie Slideshow
Photo Information
Playback with Zoom
Slideshow
Voice Memo
In-Camera Image EditingYesColor Balance
D-Lighting
Distortion Control
Edit Movie
Filter Effects
Image Overlay
Monochrome
NEF (RAW) Processing
Perspective Control
Red-Eye Correction
Resize
Side-by-Side Comparison
Straighten
Trim
GPSReceiving frequency: 1575.42 MHz (C/A code)
Geodesics: WGS 84
GP-1A GPS unit
Battery / BatteriesEN-EL18c Rechargeable Li-ion Battery
EN-EL18b/EN-EL18a/EN-EL18 batteries can also be used. Note, however, that fewer pictures can be taken on a single charge with an EN-EL18 than with an EN-EL18c/EN-EL18b/EN-EL18a.
EN-EL18a Lithium-ion Battery
Battery Life (shots per charge)3,580 shots (CIPA)
Battery enables up to approx. 3,580 shots per charge in single-frame release mode* or approx. 8,670 shots in continuous-release mode**
*Based on CIPA Standards
**Under Nikon’s own test conditions
Movies:Approx. 105 minutes of HD footage
3,780 shots (CIPA)
Movies:Approx. 110 minutes of HD footage
AC AdapterEH-6c AC Adapter; requires EP-6 Power Connector (available separately)EH-6b AC Adapter
Requires EP-6 Power Supply Connector
Approx. Dimensions (Width x Height x Depth)6.3 in.160 mm x 6.5 in.163 mm x 3.7 in.92 mm6.3 in.160 mm x 6.3 in.158.5 mm x 3.7 in.92 mm
Approx. Weight44.8 oz.1,270 g
camera body only
49.6 oz.1,405 g
with battery and two XQD memory cards but without body cap and accessory shoe cover
49.9 oz. (1,415 g)
with battery and two CompactFlash memory cards but without body cap and accessory shoe cover
Nguồn: https://nikonrumors.com/2020/02/12/nikon-d6-vs-nikon-d5-specifications-comparison.aspx/#ixzz6Du3edZ1k
