Chia sẻ KEYS FOR ESET NOD32, Kaspersky, Avast, Avira, Dr.Web, AVG. NORTON and other's [update 28.09.2019]
mariobr
Installation Instructions:
ESET NOD32
1. Open the main window of ESET NOD32
2. In the left panel, select "Settings" -> "Activate the program"
3. Then select "Username and Password"
4. Enter Username and Password -> Activate
5. Then click Finish.
Important!!! Turn off the system of timely detection.
Open the main window of ESET NOD32 -> Settings -> Go to Advanced Settings ... (F5) -> Open the "Utilities" section -> ESET Live Grid -> Uncheck "Take part in ESET Live Grid -> Click" OK "
Kaspersky
KIS / KAV 2010 version activation
In order to be able to activate the program with a key in KIS / KAV 2010, you must turn off the Internet, enter AAAAA-AAAAA-AAAAA-AAAA3 when asked for an activation code, and when you receive an error message, a window with the Browse button opens, where you can activate the program with a key (keys from 7.0 and 2009 (8.0) versions are suitable) ...
The above applies to the version (KIS / KAV 2011 version 2011 (11.0.0.232)) how to activate the assembly above this version, read below.
Note: If the "work offline" mode is enabled in Internet Explorer (even if the Internet connection is completely unavailable), this method of program activation does not work. You must disable the use of offline browser mode.
Activation of the version KIS / KAV 2011 - 2014
Avast
avast! Pro Antivirus, Internet Security, Premier 5 - 9
For Windows XP
1. Disable self-defense and replace the license file at
2. For avast! 5: “C: / Documents and Settings / All Users / Application Data / Alwil Software / Avast5 ″
2. For avast! 6–9: “C: / Documents and Settings / All Users / Application Data / AVAST Software / Avast”
3. Enable avast! Self-defense module
For Windows Vista 7, 8
2. For avast! 5: “C: / ProgramData / Alwil Software / Avast5”
2. For avast! 6-9: “C: / ProgramData / AVAST Software / Avast”
avast! Free Antivirus 5 - 9
1. Click on the tray icon, then select "Subscription Information"
2. Click on the “Enter License Key” button at the bottom of the screen.
3. Paste the key in the form field and click “ok”
Dr.Web
1. On the taskbar in the system tray, near the clock, find the Doctor Web icon.
2. Right-click on the drweb icon and select “Tools” from the menu that appears, then “License Manager” and left-click on it.
3. The "License Manager" window appears. In the window we see information about the installed drweb keys.
4. In order to install the Dr. Web antivirus key, you need to add it to the list of license manager. To do this, click on the search button and use the menu to select the desired file in the selection window that appears.
Avira
1. Open the program window and select the "Help" menu item
2. In the drop-down menu, select "License Management"
3. In the window that opens, look for the inscription "I already have a valid HBEDV.KEY license file"
4. Click on "HBEDV.KEY"
5. We show the program where the key lies.
6. We are happy with the successful activation.
mh_auth_or_registermh_auth_or_registermh_auth_or_register
