Hướng dẫn sao chép dữ liệu ra USB trong macbook
cuocsong6so
NEVER GIVE UP!
Với hệ điều hành Mac OS
Chọn Utilities>>> Disk Utility >>> Chọn USB Bạn cần Copy (Lưu ý xoá hết dữ liệu trong USB)
RSRBg8fx1yONDrWQFpxg0AWaJQ3AJuk0mHXCpXmdDWgTNYpAbvCsgLo5AE28mSFbqfycvBaHnwpMjTfDegfntzErFuOji4VThuex-wEX06MEWUKHrSEHpz03EdSvgrvHDYCJQTfcFli5xzvJ_nx420hlBBG3-uRX42AVcatrJxCGUeLtGdlAturn6kO2BwqOJyJQaCodXsD1oftfqpqqE1pyTKD7509XAEtjzt94XtlanWK7uZ2yVWJhIAyI9fX1I9YwjX3gxeRvZXMqKOAFydGrDtlms2Hgjfe3sBMoydHUQBDfJBNxnuTZn8-8ZgREAX1cJRlN_DLDfI3ey0tmrbRbbj-t_OvY3nG5NMSYqnl7TgUfCc_CgoKishApcmMAed79x2MDw4TI6jl7EsQz0SUurVDogKDdn5Mirr6WzRGh8gPr-VFB6oPCQdbZc8ZZiEuko1S04ex1YgCXT-2_dhLJsJCfjculr2hMOLX_uPhCKqAPII_AcXTYK91nUm0dq-y-8ieX58qzTf1m3MZnO2UTPVRkV62qlnfFHP6Fo0pzlYEYRuQeBblgzSaQ-rIJIHLCIla-qsUvaUiF3WAt_9tYfSdejID1fdypPPd5nWnT8UedT2DwAOFqxmwM2Ds=w1122-h631-no
Chọn Erase>> Format USB với định dạng ExFAT
jTj4uchmai7OxhZ1x_YYxHQsrTHSJSU5QglUReilU32NAGJ5Fi5fykytJo3JnuZpIVzyMB4MMjgyqfHCGl35m2fnBdwCZxQRiyr4sPHAhOFwwcq9sVbsoM7ueGhzRdD4NswKgA17DWKwd5Jpgso6qsEQgKHgbCycAXCjqXC3BWhm95qz1l3Zm7NyRXBQmNYttSapPSjpILdED3GggNgk1oqTCo2f4D00wZRFbAdlSeeQZZM4JmF0zoXv3bKGQ6954_t6M-rKpBAb0jpxjSRZB2HbFEzkzAlNiSwK-zo1BSV9vnEeeW8YlC_qczpqK7BCdq-HT22LSJhSEIfotJRHApRwCPRjy9GjUooQLujQOzZDLEVD-MeV9kgoYrS8nAQOVFEIVu-5u0Fbo711w6gehSwWx-E6sii__ZgcBroM0FSqO5hqi_StMUgFdxOVTsKQ-YkWkIt_Nv-nwh65LXSxkH7u0VUs925Ge4FltnLqoKJtaBOxYTPOU-cVKxv5pvtGauxpqSkIj2ytjFTX75FZFGR5INgbNFalX5jAOL8PnUBA40JFwqrDw8VRHxJWhJYKFbu01w3CgK8PFlRYKXyhXNvcjWXhKhnZicmyWVdaJEKAKWyl-o1DdnzsOme1tBw=w733-h631-no
Ấn Erase
MHeI9pyfFYtDFSy4Mxz-A4KJm0Xj4haKXjkRrElEoRl4UraLdcMoiI2jYxIfSr78lNPh_MJ5wPEUO3GmStgLEfyRjVxgv3ysr3fjB5eSKdr6wPXQG0Tvdy2CHXKmVKckYMyU5MyVaimrIO3jDrbMqBpAG3fPN8sTkO7yM-BKJoyqOkGaQC9CN8NEEZrp3GfPvNnkhM_cc3NgjdEHYAy4g_VGejJGnPXPXlhkk7PVqmT8Pkoqmzhrud7fy1U65JiJAdyjRVMtOXKvQup_AL_5tUuGevThI1aljNM9UvJSfqvHMIbHWrx-L--9FmxztcYQkTuN_Fl8zUO-dwxvL0I2Ytr3of4Q5Ua3FVVElOXis404Wd8rcprsheaKG2LWIiYYgnJSrkwwWeiSE4no4IuTyBU29pAgKUGKqRNUThXaA1vxmOQ7CZEhAtp1_ajg9aiF56RFogyfveKFG-0ws5ARtRPeDxEjDGS3kyKEL8a4uO4aR1QT-zC7AdUrdT-tibSIffDaSAw7f5xXsdxwFXaQ26vMyw-Ne0QAeOPg2cv1LTCQyYOKl8I9mqln9joD0BZ9SuJzIRGC4s4c-epkVFn5TZ1pwdPyTyr3DzGKzcfejOEijOMNK2_jPQZi7dv8xYo=w729-h631-no
Giờ thì Copy dữ liệu vào USB thoải mái
MZsdHuX3xwMZ9yupdMkOwctzBofuCjcRdmas7r9FaTYP2fLBkgRsurZ_ClSKN1R0dzDdB5izFH0HdQxzmJ3ehbMtWMw0_NBJ7NcgAAeFTABDp04xyGm7HvkRKHitbMjHaDStgMYbQ7y0yw8OMrmmR7Sw2Vlfdj-BOzxADYMCTFQ85X8OOZC3jhwJy6AjXVQOFY8pnYYwpgJc01QigiJnF5K_59hYqCyVNgdGiGutVDNh4Kot4KFEIMowFiixX1QYqBryYHaiJCxDMousTLYCA9_96NSANDWf-qW0C7dlurFiJ0g5LIIcEfkkI5iiQJW5--TW2nJio564R18u1ervwduG667-343lCYqQNd2MQxG-btFD_utagBMkPbrvOtsta0-oU8RI_B5A-Gl5N9h7JUL-HpON1_GHDfoaHmWiz9gKriRPlDaHkRh-gNVw6whFKQNuQkOJ-6d6-xvVelzazwK4-8_zkGOFEiJNfDO0AbVNhXyemWV19j1q4z0OcmLzSHY2Q0oN-2tOARa7THApAm_QQ-tXU-MlU_4PuDc4Bbs3bK4vErjmsCOmiYSdlFyXNwOm1cVVu_FfjU_Mh_l_GaRuDoQ0u4qMBKijyeFYww2ZVP0cM2GcrKvfxaV8WII=w773-h441-no
#3
Cắm usb bình thường vào vẫn nhận cơ mà nhỉ, tại sao lại phải định dạng lại nó vậy bạn. usb bình thường có bao giờ có định dạng NTFS đâu ?
#6
Mac và Win đọc được chung định dạng Fat32, cứ cho usb format dạng này là cắm đâu cũng xài được, điểm yếu định dạng này là không lưu được file trên 4GB
XuxiLady
#7
Bác có dùng hệ điều hành TÁO ko
Macintosh chỉ hỗ trợ HFS+, exFAT và FAT32 thôi hai bác. Windows thì có hỗ trợ thêm NTFS nữa. NTFS thì chép được các tệp tin trên 4GB nên tiện lưu phim, phần mềm dung lượng lớn hơn. ExFat thì em chưa có cơ hội thử nhưng hồi trước cài Hackintosh thì được khuyên là không nên dùng vì rủi ro mất dữ liệu cao.
Trên Mac thì người dùng có thể cài thêm Paragon NTFS hoặc Tuxera NTFS để hỗ trợ đọc ghi các phân vùng NTFS, tiện cả đôi đường.
Mình vẫn dùng định dạng ExFat cho ổ đĩa di động và usb như thường, về cơ bản thì chỉ có tự format usb về định dạng NTFS thì mac(không cài pm) mới không đọc được thôi. Chẳng hiểu sao lại có bài hướng dẫn này :D
XuxiLady
#9
Ừhm, mình nhớ là Mac đọc NTFS bình thường, chỉ không ghi được thôi. Cơ mà thế thì hơi tù, theo ý mình ^^.
