[AdGuard] Nightly.
AdGuard for Windows | version 7.2.2910.0 from August 30, 2019
* [Feature] AdGuard does not filter Iridium browser: #2918
* [Feature] Incompatibility with Epic Browser: #2927
* [Feature] UI elements should be aligned: #2922
* [Feature] Upgrade CoreLibs to 1.4.157: #2928
* [Fix(regression)] Failed test: Uninstallation via uninstall shortcut: #2916
AdGuard for Windows | version 7.2.2917.0 from September 9, 2019
* [Fix(regression)] Minor interface issues.: #2761
* [Fix(regression)] Notification does not disappear on Windows 7: #2873
* [Fix] Invalid path is passed in the excluding apps section (advanced settings): #2933
AdGuard for Windows | version 7.2.2921.0 from September 12, 2019
* [Feature] Update Assistant and Wot to 4.3.18 and 1.1.16 respectively: #2942
AdGuard for Windows | version 7.2.2931.0 from September 17, 2019
* [Feature] Additionally inform user about reboot required: #2946
* [Feature] Spellcheck improvements: #2962
* [Feature] Update CoreLibs to 1.4.161: #2959
* [Feature] Window buttons tooltip localization: #2953
* [Fix] Support dialog - e-mail typing issue: #2951
AdGuard for Windows | version 7.2.2937.0 from September 19, 2019
* [Feature] Restrict sent logs' length in the installer crash reporter: #2968
* [Feature] Update CoreLibs to 1.4.165: #2975
* [Fix] Couldn't enable the proxy mode: #2974
* [Fix] The port field is always highlighted: #2976
* [Fix] WFP driver incompatibility with Emsisoft software: #2957
