[AdGuard] Nightly.
AdGuard for Windows | Version 7.0.2640.6555
* [Feature] Adguard Assistant -> AdGuard Assistant: #2643
* [Feature] Trial & license screen UI changes: #2657
* [Feature] Update CoreLibs to 1.3.335: #2661
* [Feature] Update Corelibs to 1.3.340: #2668
* [Fix] "BlockTypeRuleDescription" wrongly used as a rule in the filtering log: #2663
* [Fix] Notification's text is out of its bounds : #2662
* [Fix] ObjectDisposedExceptionAdguard in Logger.Error(): #2667
* [Fix] The English language is set by default: #2664
AdGuard for Windows | Version 7.0.2653.6581
* [Feature] Add filter button in UI: #2674
* [Feature] Update to Corelibs 1.3.348: #2669
* [Fix] ArgumentException in UserscriptInstallDialogViewModel: #2673
P/s: Bà con cô bác nào mà đi theo build này update mệt nghĩ.................
cho mình hỏi, cách đổi giờ và block domain để giữ trial cho Adguard Full còn làm được không.
Mình có copy list block domain vào file host r,Adguard có reset trial r nhưng mìnhđổi lại giờ cái là lại mất trial.
Cámơn b
Cámơn b
Block hosts giờ chỉ dành cho bản 6 thôi, còn bản 7 thì xem ở #42
AdGuard for Windows | Version 7.0.2690.6655
* [Feature] Update CoreLibs to 1.3.351: #2684
* [Feature] Update to Corelibs 1.3.350: #2681
* [Fix] An error while update/reinstall userscript from the local file: #2679
* [Fix] Minor changes in UI: #2678
* [Fix] Wrongly used Simplified Chinese character encoding in about (Traditional Chinese interface)?: #2680
anhl0v3ga
bác ơi, patch của bác không hoạt động trên bản 7 :(
Adguard for Windows | Version 7.0.2708.6691
* [Feature] Change the filters auto-detect algorithm: #2692
* [Feature] Update CoreLibs to 1.4.13: #2712
* [Fix] AdGuard label is missed on the release version: #2695
* [Fix] Compatibility issues with Sophos AV: #2710
* [Fix] InvalidOperationException in AdblockerFilterEditorViewModel: #2708
* [Fix] Userscript's update channel mismatch: #2694
* [Fix] [Rules constructor] Add `$important` to the rules, created for whitelisted requests only: #2677
itunnel
AdGuard này có share key được ko nhỉ? Đang có offer lifetime license mà key cũng 750k khá chát. {bad_smelly}
Adguard update Version 7.0.2807
* [Feature] Show the domain name in the filtering log in case of non-decoded connection if it possible: #2691
* [Feature] Update Corelibs to 1.4.18: #2758
* [Feature] Update Corelibs to 1.4.20: #2762
* [Fix] "Hide IP" section doesn't invoke an error, when the custom IP value is invalid: #2713
* [Fix] AdGuard settings work very slow when Parental Control is enabled: #2687
* [Fix] Error while creating languages combobox: #2685
* [Fix] The Hide User-Agent field is not automatically flagged in the problem report form: #2732
Adguard update Version 7.0.2812
* [Feature] Show only significant version parts in the UI (trim trailing zeroes): #2763
* [Feature] Update Corelibs to 1.4.25: #2771
* [Feature] Update Corelibs to 1.4.27: #2774
* [Fix] CA certificate is installed into the wrong store in some cases: #2756
Adguard update Version 7.1.2815
* [Feature] Update CoreLibs to 1.4.31: #2775
* [Fix(regression)] AG certificate is not removed on the app uninstall or reinstall: #2772
Adguard update Version 7.1.2818
* [Feature] Update CoreLibs to 1.4.32: #2777
AdGuard for Windows | version 7.1.2898.0 from August 16, 2019
* [Feature] Allow access to the "settings", "about" and "support" sections even if failed to enable protection : #2892
* [Feature] Update CoreLibs to 1.4.152: #2906
* [Fix] 7.1.2894.0 breaks Windows 7: #2904
AdGuard for Windows | version 7.1.2894.0 from August 15, 2019
* [Feature] Update CL to 1.4.150: #2902
* [Feature] Update CoreLibs to 1.4.136: #2894
* [Feature] Update CoreLibs to 1.4.145 : #2899
AdGuard for Windows | version 7.1.2885.0 from August 9, 2019
* [Fix] AdGuard does not handle alphanumeric versions properly: #2876
* [Fix] AdGuard never finishes updating and hangs: #2856
AdGuard for Windows | version 7.1.2883.0 from August 7, 2019
* [Feature] Update WFP/TDI drivers to the new version (6.3.32): #2889
AdGuard for Windows | version 7.1.2880.38 from August 6, 2019
* [Feature] Start using the crash reporting within the installer: #2566
* [Feature] Update CoreLibs to 1.4.131: #2881
* [Feature] Update CoreLibs to 1.4.133: #2885
* [Fix(regression)] Add "Filter localhost" checkbox to the advanced settings: #2830
* [Fix] Notification does not disappear on Windows 7: #2873
* [Fix] Packages cache (msi files) are not removed after the update: #2886
AdGuard for Windows | version 7.1.2874.0 from August 1, 2019
* [Feature] Update CoreLibs to 1.4.127: #2871
* [Fix] Severe cases of service connection errors on Windows 10: #2843
AdGuard for Windows | version 7.1.2872.0 from July 25, 2019
* [Feature] Move translations from OneSky to Crowdin: #2852
* [Feature] Update CoreLibs to 1.4.120: #2863
* [Fix] Https filtering is disabled by default for the newly added applications: #2846
AdGuard for Windows | version 7.1.2868.0 from July 22, 2019
* [Feature] Add "Filter localhost" checkbox to the advanced settings: #2830
AdGuard for Windows | version 7.1.2866.0 from July 17, 2019
* [Feature] Implement filter subscription detection message's handler: #2517
* [Feature] Update CoreLibs to 1.4.96: #2850
* [Fix] Broken layout of the "import filter" dialog: #2842
* [Fix] Chinese date is over the frame of pop-up message in v7.1.2861ƞ.: #2849
AdGuard for Windows | version 7.1.2861.0 from July 16, 2019
* [Feature] Change Settings Selector Color in Dark Mode: #2749
* [Feature] Update CoreLibs to 1.4.91: #2848
* [Feature] Use custom adguard: scheme for adding userscripts : #2838
* [Fix] Connections are closed when configuration is reloaded: #2841
* [Fix] Error after updating to the latest nightly: attempt to connect to not available service: #2802
* [Fix] Minor UI issue on the About screen: #2790
* [Fix] Minor interface issues.: #2761
* [Fix] Stealth mode settings are reset after v6.4->v7.1 upgrade: #2839
* [Fix] The "IsUpdateAvailable" isn't refreshed after the channel update changing: #2806
* [Fix] Wrong feature description: #2794
AdGuard for Windows | version 7.1.2848.0 from July 5, 2019
* [Feature] Add atom to the browser list: #2688
* [Feature] Adguard GUI unnecessarily raising Windows platform timer resolution: #2734
* [Feature] Change the size of the place: #2698
* [Feature] Do not use same window for support dialogue: #2619
* [Feature] Update CoreLibs to 1.4.78: #2816
* [Fix(regression)] Accessibility issues: #2682
* [Fix] Mark blocked stun/turn request in the filtering log: #2638
* [Fix] Text is not visible on dark theme: #2767
* [Fix] The application is not started after update: #2798
AdGuard for Windows | version 7.1.2838.0 from July 2, 2019
* [Feature(regression)] Change the filters auto-detect algorithm: #2692
* [Feature] Update CoreLibs to 1.4.67: #2801
* [Fix] Post Installation Sequence: #2750
AdGuard for Windows | version 7.1.2836.0 from July 1, 2019
* [Feature] Change the FF cert issues auto-detect: #2782
* [Feature] Update CoreLibs to 1.4.65: #2796
* [Feature] Update Corelibs to 1.4.56: #2789
* [Fix] Accessibility issues: #2682
AdGuard for Windows | version 7.2.2901.0 from August 22, 2019
* [Feature] 7.1.2885.0 unnecessary errors in the log file: #2897
* [Feature] Advanced settings: rename "use localhost for injections" into "Intercept TCP connect requests": #2859
* [Feature] Installer redesign: #2574
AdGuard for Windows | version 7.2.2903.0 from August 26, 2019
* [Feature] Update CoreLibs to 1.4.55: #2919
* [Fix] Failed test: Uninstallation via uninstall shortcut: #2916
