[AdGuard] Nightly.
r4Rocky
Hi @r4Rocky, just a courtesy reminder, it would be better if you could correct the first word from: "Adard" to " Adguard ".
Best regards,
Old member.
Thanks for heads up @Hoang Duch2, it was a big typo.... the first word of the post wrongly spelled. Actually, it's all because my constant shuffle between English and Vietnamese GUI.
To read I change to English, and write a thread/post to VNZ-native language.
AdGuard for Windows version 7.0.2358.5991 from March 20, 2019
  • [Feature] Dark theme -- the font is too bright: #2446
  • [Feature] Update CoreLibs to 1.3.221: #2518
  • [Feature] Update CoreLibs to 1.3.222: #2520
  • [Feature] Update CoreLibs to 1.3.223: #2522
  • [Fix] KeyNotFoundException in OnHtmlElementRemoved : #2515
  • [Fix] NullReferenceException in ToastNotificationManager: #2494
AdGuard for Windows version 7.0.2372.6019 from March 22, 2019
  • [Feature] Decrease the scroll speed in settings UI: #2514
  • [Feature] Update CoreLibs to 1.3.232: #2527
  • [Fix] An issue with the userscripts updating: #2500
  • [Fix] Crash after the completing custom filter installation: #2467
  • [Fix] Greasy Fork userscripts display Error when checking for updates: #2447
  • Fix] Self-destructing third-party cookies default setting is inconsistent: #2448
AdGuard for Windows version 7.0.2408.6091 from March 29, 2019
* [Feature] Update to CoreLibs 1.3.250: #2543
AdGuard for Windows version 7.0.2405.6085 from March 27, 2019
* [Feature] Update CoreLibs to 1.3.246: #2538
AdGuard for Windows version 7.0.2388.6051 from March 27, 2019
  • [Feature] Scroll Issues: #2534
  • [Feature] Update CoreLibs to 1.3.241: #2533
AdGuard for Windows version 7.0.2435.6145 from April 3, 2019
  • [Feature] Update to CoreLibs 1.3.258: #2557
  • [Fix(regression)] AdGuard doesn't delete crashreports of service: #2468
AdGuard for Windows version 7.0.2430.6135 from April 3, 2019
  • [Feature] Add Chromium-based Microsoft Edge to the filtered applications list: #2548
  • [Feature] Update to CoreLibs 1.3.253: #2552
  • [Fix(regression)] AddRuleDialogViewModel crashes with the null-length string: #2466
thinhnhd1
What is new in version 7.0.2463.6201 (Released on April 12, 2019):
  • [Feature] Update CoreLibs to 1.3.278;
  • [Fix] Custom filters always look like they were updated;
  • [Fix] InvalidOperationExceptionAdguard in App.Show();
  • [Fix] The log record wrongly marked as "cosmetic".
What is new in version 7.0.2454.6183 (Released on April 10, 2019):
  • [Feature] Add Kinza browser support;
  • [Feature] Filtering log issues;
  • [Feature] Update CoreLibs to 1.3.275;
  • [Feature] Use Chinese date format for filters' update time in Chinese interface;
  • [Fix] Do not count rules from disabled filter lists;
  • [Fix] Empty lines in custom filter imported as rules;
  • [Fix] Unable to enter a license key, the field is locked;
  • [Fix] Version number in about window not selectable anymore.
What is new in version 7.0.2430.6135 (Released on April 03, 2019):
  • [Feature] Add Chromium-based Microsoft Edge to the filtered applications list;
  • [Feature] Update to CoreLibs 1.3.253;
  • [Fix(regression)] "AddRuleDialogViewModel" crashes with the null-length string.
Fix vẫn chạy tốt
thinhnhd1
What is new in version 7.0.2475.6225 (Released on April 16, 2019):
  • [Feature] Enable Asyncronous OCSP check;
  • [Feature] Update CoreLibs to 1.3.281.
AdGuard for Windows | version 7.0.2495.6265 from April 20, 2019
* [Fix] NullReferenceException in ToastNotification: #2587
AdGuard for Windows | version 7.0.2528.6331 from April 24, 2019
* [Feature] Allow to export/import system settings (UI theme Id, window's height and width, etc.) along with the app settings: #2393
* [Feature] Update CoreLibs to 1.3.304: #2593
* [Fix] Applied cookie rule wrongly marked as "Whitelisted" in the filtering log: #2590
* [Fix] Don't ignore empty lines when comparing subscriptions' content: #2589
* [Fix] Error deleting Backups\fail.dat: #2582
* [Fix] Filtering log - suggested rules are incorrect for $csp rules: #2485
* [Fix] Subscriptions' update errors wrongly mark as an 'Up to date': #2588
* [Fix] User filter edit box bug.: #2584
Adguard version 7.0.2528.6331 from April 24, 2019 | đã cập nhật lại đăng ký, cho nên sẽ xảy ra hiện tượng bị fix giấy phép nhé.
Mình hiện tại dùng fix trial nên thấy bình thường, vẫn xài Vô Tư luôn
2019-04-25_080718-png.3660
Tôi dùng key khuyến mãi , mà cập nhật kênh Nightly này nó lỗi service hoài , chuyển sang Release 2 hôm thì ko còn bị lỗi of service nữa
Nightly là bản chỉ để dành cho các bạn tester thử nghiệm trước khi lên bản Beta rồi từ tester lại ra phiên bản chính thức.
Nói chung bản Nightly này chỉ dành cho nhưng ai muốn tìm hiểu những cái mới mà Dev tạo ra trước nhất.
Còn muốn ổn định thì dùng bản ổn định ! Nếu dùng Beta thì thà xài Nightly luôn cho rồi :)
P/s: Mình đây xài fix nên ko thể để update chay được toàn nâng cấp từ setup lên
AdGuard for Windows | version 7.0.2548.6371 from April 29, 2019
* [Feature] Update CoreLibs to 1.3.312: #2602
* [Feature] [Nightly] Filtering log - open url: #2599
* [Fix] CollectionView is not in dispatcher thread on Reload: #2603
* [Fix] Remove BOM from the userscript content: #2601
AdGuard for Windows | version 7.0.2541.6357 from April 26, 2019
* [Feature(regression)] Handle runtime ff-certificate issues: #2390
* [Feature] Change triple click behavior in Filtering log: #2595
* [Feature] Update CoreLibs to 1.3.306: #2596
* [Feature] Update CoreLibs to 1.3.307: #2597
* [Fix] Active Install button in New Filter Subscription window: #2472
* [Fix] ConfigurationErrorsException while checking the user config: #2594
* [Fix] [Nightly] Filter Editor - Home button issue: #2530
AdGuard for Windows | version 7.0.2552.6379 from April 30, 2019
* [Feature] [Filtering log] Clicking on blank space in requests selector does nothing: #2607
* [Fix] NullReferenceException in IsMsEdgeTcpFastOpenEnabled: #2605
AdGuard for Windows | Version 7.0.2561.6397
* [Feature] Update CoreLibs to 1.3.313: #2613
* [Fix] Cannot invoke action Show on the notification as the item not found: #2604
* [Fix] Error while importing AGW 6.4 userscripts: #2606
AdGuard for Windows | Version 7.0.2582.6439
* [Fix] "Nightly" update channel is reset to the "Release" when resetting settings to default: #2614
* [Fix] Custom windows sizes are not saved after update to new version: #2608
* [Fix] Incorrect translation: #2616
* [Fix] OutOfMemoryException occurs while handling the native exceptions: #2612
AdGuard for Windows | Version 7.0.2584.6443
* [Feature] Let users add/remove filter lists from the General settings: #2620
* [Fix] Can only call DragMove when primary mouse button is down.: #2621
* [Fix] [Nightly] Main window very slow: #2618
AdGuard for Windows | Version 7.0.2591.6457
* [Feature] Translation mistake: #2626
* [Fix(regression)] Greasy Fork userscripts display Error when checking for updates: #2447
* [Fix] ArgumentNullException in LicenseDialogViewModel: #2636
* [Fix] Can AG not automatically detect Windows system language?: #2622
* [Fix] Filter name is in the Rule column: #2634
* [Fix] InvalidOperationException in ToastWindow.Show() : #2639
* [Fix] License activation pop-up: #2628
AdGuard for Windows | Version 7.0.2617.6509
* [Feature] Add "AdGuard Extra" extension: #2648
* [Feature] Update CoreLibs to 1.3.325: #2645
* [Fix] Rule Editor suggest wrong exclusion for $$ rules: #2630
AdGuard for Windows | Version 7.0.2626.6527
* [Feature] Extend filtering log search syntax: #2651
* [Feature] Update to CoreLibs 1.3.333: #2660
* [Fix] Adguard hangs after the wake up: #2649
* [Fix] Error while doing the update check: #2654
* [Fix] NullReferenceException in IsWindowsShellLoaded: #2655
* [Fix] NullReferenceException in NetworkFilteringService: #2656
